Observer design for linear switched systems: a common Lyapunov function approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
In this paper, we give sufficient conditions for the stability of a class of switched systems. Based on the symmetric part of the state space matrix and on the LaSalle's invariance principle, to ensure the asymptotic stability of switched linear systems, under a special class of switching signals. The proposed stability results are used to design observer of switched linear systems for which the discrete state is available. Examples are given to highlight our propositions.
Fichier non déposé
hal-01056284 , version 1 (18-08-2014)
  • HAL Id : hal-01056284 , version 1
Salim Chaib, Driss Boutat, Abderraouf Benali, Jean Pierre Barbot, Jean Claude Guillot. Observer design for linear switched systems: a common Lyapunov function approach. IEEE International Conference on Control Applications, Oct 2006, munich, Germany. ⟨hal-01056284⟩
258 Consultations
0 Téléchargements
