Privacy Preserving Key Generation for Iris Biometrics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work we present a new technique for generating cryptographic keys out of iris textures implementing a key-generation scheme. In contrast to existing approaches to iris-biometric cryptosystems the proposed scheme does not store any biometric data, neither in raw nor in encrypted form, providing high secrecy in terms of template protection. The proposed approach is tested on a widely used database revealing key generation rates above 95%.
rathgeb_uhl.pdf (189.22 Ko) Télécharger le fichier
hal-01056379 , version 1 (18-08-2014)
Paternité
Christian Rathgeb, Andreas Uhl. Privacy Preserving Key Generation for Iris Biometrics. 11th IFIP TC 6/TC 11 International Conference on Communications and Multimedia Security (CMS), May 2010, Linz, Austria. pp.191-200, ⟨10.1007/978-3-642-13241-4_18⟩. ⟨hal-01056379⟩
142 Consultations
189 Téléchargements
