Towards an Understanding of E-Government Induced Change - Drawing on Organization and Structuration Theories - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
E-government research deals with 'wicked' problems that require multidisciplinary approaches to gain a full understanding. One of the main challenges of e-government is to induce change in the structure of public organizations to realize its full potential. This paper investigates e-government induced change using two complementary theoretical lenses applied to an e-government case study. We use organization theories to explore aspects of organizational structure that may change when implementating e-government and structuration theory to investigate how these aspects are affected by human action within its social structure. This combination allows us to investigate the discrepancy between the ambitions of e-government induced change and the actual changes accomplished in practice. Our analysis shows that using these two frames gives us better insight into the thorny subject of e-government than using a single theory. Further research should look into how these theories can be used to deepen our knowledge of e-government.
paper_57.pdf (109.55 Ko) Télécharger le fichier
hal-01056584 , version 1 (20-08-2014)
Paternité
Anne Fleur Veenstra, Marijn Janssen, Yao-Hua Tan. Towards an Understanding of E-Government Induced Change - Drawing on Organization and Structuration Theories. 9th IFIP WG 8.5 International Conference on Electronic Government (EGOV), Aug 2010, Lausanne, Switzerland. pp.1-12, ⟨10.1007/978-3-642-14799-9_1⟩. ⟨hal-01056584⟩
96 Consultations
269 Téléchargements
