Performance Evaluation of Non-parallelizable Client Puzzles for Defeating DoS Attacks in Authentication Protocols - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2010
We provides an evaluation of non-parallelizable puzzles used to prevent DoS in authentication protocols. With an evaluation based on a simulation and performance analysis, this approach helps a responder to resist against DoS, as well as improves the throughput of services for legitimate clients. Another key strength is that the construction and verification at the responder is simple and fast.
_22.pdf (92.3 Ko) Télécharger le fichier
Dates and versions
hal-01056672 , version 1 (20-08-2014)
Attribution
Identifiers
Cite
Suratose Tritilanunt. Performance Evaluation of Non-parallelizable Client Puzzles for Defeating DoS Attacks in Authentication Protocols. 24th Annual IFIP WG 11.3 Working Conference on Data and Applications Security and Privacy (DBSEC), Jun 2010, Rome, Italy. pp.358-365, ⟨10.1007/978-3-642-13739-6_28⟩. ⟨hal-01056672⟩
76 View
111 Download
Share
