Bending and crumpling effects on a wearable planar monopole antenna - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A Coplanar WaveGuide (CPW) monopole antenna designed to operate at the frequency (fr) of 2.05 GHz and intended to be put over a fabric is tested with respect to substrate deformations. In absence of deformations, the antenna bandwidth is 18.8% and its reflection coefficient is -44 dB. Deformations tested are bending in the H or the E-plane, crumpling and a combined situation. Results show that bending effect will not greatly affect the antenna in realistic situations (i.e. bending radius bigger or equal to 5 cm). Crumpling effect is more important and should be prevented.
Fichier non déposé
hal-01056710 , version 1 (20-08-2014)
Tsitoha Andriamiharivolamena, Pierre Lemaitre-Auger, Darine Kaddour, Smail Tedjini, Franck Tirard, et al.. Bending and crumpling effects on a wearable planar monopole antenna. Antenna Technology and Applied Electromagnetics (ANTEM), 2012 15th International Symposium on, Jun 2012, Toulouse, France. pp.1-4, ⟨10.1109/antem.2012.6262384⟩. ⟨hal-01056710⟩
70 Consultations
0 Téléchargements
