3D steering of a flexible needle by visual servoing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a robotic control method for 3D steering of a beveled-tip flexible needle. The solution is based on a new duty- cycling control strategy that makes possible to control three degrees of freedom of the needle. A visual servoing control scheme using two or- thogonal cameras observing a translucent phantom is then proposed to automatically steer a needle toward a 3D target point. Experimental results show a final positioning error of 0.4 mm and demonstrate the feasibility of this promising approach and its robustness to model errors.
2014_miccai_krupa.pdf (914.09 Ko) Télécharger le fichier
hal-01057949 , version 1 (25-08-2014)
  • HAL Id : hal-01057949 , version 1
Alexandre Krupa. 3D steering of a flexible needle by visual servoing. Int. Conf. on Medical Image Computing and Computer Assisted Intervention, MICCAI 2014, Sep 2014, Boston, United States. pp.480-487. ⟨hal-01057949⟩
397 Consultations
177 Téléchargements
