The Impact of Electronic Medical Records on the Work Process of Outpatient Care: Extracting Use-Cases of Paper-based Medical Records using a Time Process Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The goal of this study is to measure the impact of electronic medical records on both time efficiency and the work process with regard to outpatient care. In this study, we focus on examining the pre-assessment ahead of the introduction of the electronic medical records procedure applying new methodology, time process study. We extracted 12 use-cases and 82 actions in relation to paper based medical records at an outpatient department at a university hospital using time process study. The results suggest that, for nurses, indirect management of patients accounted for a higher proportion of the use-cases than was the case for direct care.
p-5manuscript_ShimizuS.pdf (26.19 Ko) Télécharger le fichier
hal-01059547 , version 1 (01-09-2014)
Paternité
Sachiko Shimizu, Yuko Ohno, Hiroko Noda, Shohei Nakamura, Ichiro Kanaya, et al.. The Impact of Electronic Medical Records on the Work Process of Outpatient Care: Extracting Use-Cases of Paper-based Medical Records using a Time Process Study. First IMIA/IFIP Joint Symposium on E-Health (E-HEALTH) / Held as Part of World Computer Congress (WCC), Sep 2010, Brisbane, Australia. pp.230-231, ⟨10.1007/978-3-642-15515-4_27⟩. ⟨hal-01059547⟩
116 Consultations
119 Téléchargements
