Periodic motions of coupled impact oscillators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study existence of time-periodic oscillations in a chain of coupled impact oscillators, for rigid impacts without energy dissipation. We formulate the search of periodic solutions as a boundary value problem incorporating unilateral constraints. This problem is solved numerically and different solution branches corresponding to nonlinear localized modes (breathers) and normal modes are computed.
ajp.pdf (165.02 Ko) Télécharger le fichier
hal-01059824 , version 1 (02-09-2014)
  • HAL Id : hal-01059824 , version 1
Vincent Acary, Guillaume James, Franck Pérignon. Periodic motions of coupled impact oscillators. ENOC 2014 - 8th European Nonlinear Dynamics Conference, Jul 2014, Vienna, Austria. ⟨hal-01059824⟩
153 Consultations
127 Téléchargements
