Requirement Driven Service Composition: An Ontology-Based Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Service-oriented computing is a new computing paradigm that utilizes services as fundamental elements for developing applications. Service composition plays a very important role in it. This paper focuses on service composition triggered by service requirement. Here, the processes modeling the requirement should be treated in parallel with describing service and a same ontology should be adopted for allowing the understanding between the requirement and services. An effect-based approach has been proposed based on our previous work on service description. This approach could be promising for tackling the challenge of services composition.
3400018.pdf (392.98 Ko) Télécharger le fichier
hal-01060354 , version 1 (04-09-2014)
Paternité
Guangjun Cai. Requirement Driven Service Composition: An Ontology-Based Approach. 6th IFIP TC 12 International Conference on Intelligent Information Processing (IIP), Oct 2010, Manchester, United Kingdom. pp.16-25, ⟨10.1007/978-3-642-16327-2_6⟩. ⟨hal-01060354⟩
59 Consultations
85 Téléchargements
