Supporting Streams of Changes during Branch Integration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Science of Computer Programming Année : 2014
When developing large applications, integrators face the problem of integrating changes between branches or forks. While version control systems provide support for merging changes, this support is mostly text-based, and does not take the program entities into account. Furthermore, there exists no support for assessing which other changes a particular change depends on have to be integrated. Consequently, integrators are left to perform a manual and tedious comparison of the changes within the sequence of their branch and to successfully integrate them. In this paper, we present an approach that analyzes changes within a sequence of changes (stream of changes): such analysis identifies and characterizes dependencies between the changes. The approach identifies changes as autonomous, only used by others, only using other changes, or both. Such a characterization aims at easing the integrator's work. In addition, the approach supports important queries that an integrator otherwise has to perform manually. We applied the approach to a stream of changes representing 5 years of development work on an open- source project and report our experiences.
2014-07-09-main-JournalSpecialIssue.pdf (906.89 Ko) Télécharger le fichier
hal-01060534 , version 1 (03-09-2014)
Verónica Uquillas-Gomez, Stéphane Ducasse, Andy Kellens. Supporting Streams of Changes during Branch Integration. Science of Computer Programming, 2014, 96, pp.84-106. ⟨10.1016/j.scico.2014.07.012⟩. ⟨hal-01060534⟩
123 Consultations
210 Téléchargements
