MIMO RADAR PERFORMANCE ANALYSIS UNDER K-DISTRIBUTED CLUTTER
The resolvability of two closely-spaced signals is an important performance measure for parametric estimation problems. In this paper we investigate the so-called resolution limit (RL) in a MIMO radar context, i.e., the minimum angular separation required to resolve two closely-spaced targets. Due to the limited number of elementary scatterers, the Gaussian modeling of the clutter is inappropriate. In our analysis, we consider a K-distributed clutter which is a wellestablished approximation of the real clutter. Finally, our RL's expression reveals a number of insightful properties that are discussed in detail and, numerical examples are provided to corroborate the theoretical analysis.
