Automatically Designing Robot Controllers and Sensor Morphology with Genetic Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Genetic programming provides an automated design strategy to evolve complex controllers based on evolution in nature. In this contribution we use genetic programming to automatically evolve efficient robot controllers for a corridor following task. Based on tests executed in a simulation environment we show that very robust and efficient controllers can be obtained. Also, we stress that it is important to provide sufficiently diverse fitness cases, offering a sound basis for learning more complex behaviour. The evolved controller is successfully applied to real environments as well. Finally, controller and sensor morphology are co-evolved, clearly resulting in an improved sensor configuration.
BonteW10.pdf (1018.33 Ko) Télécharger le fichier
hal-01060655 , version 1 (17-11-2017)
Paternité
Bert Bonte, Bart Wyns. Automatically Designing Robot Controllers and Sensor Morphology with Genetic Programming. 6th IFIP WG 12.5 International Conference on Artificial Intelligence Applications and Innovations (AIAI), Oct 2010, Larnaca, Cyprus. pp.86-93, ⟨10.1007/978-3-642-16239-8_14⟩. ⟨hal-01060655⟩
48 Consultations
55 Téléchargements
