Automatically Designing Robot Controllers and Sensor Morphology with Genetic Programming
Genetic programming provides an automated design strategy to evolve complex controllers based on evolution in nature. In this contribution we use genetic programming to automatically evolve efficient robot controllers for a corridor following task. Based on tests executed in a simulation environment we show that very robust and efficient controllers can be obtained. Also, we stress that it is important to provide sufficiently diverse fitness cases, offering a sound basis for learning more complex behaviour. The evolved controller is successfully applied to real environments as well. Finally, controller and sensor morphology are co-evolved, clearly resulting in an improved sensor configuration.
