A Tool for Automatic Creation of Rule-Based Expert Systems with CFs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper introduces a tool, namely ACRES (Automatic CReator of Expert Systems), which can automatically produce rule-based expert systems as CLIPS scripts from a dataset containing knowledge about a problem domain in the form of a large number of cases. The rules are created via a simple systematic approach and make use of certainty factors (CFs). CFs of same conclusions can be combined either using the MYCIN method or a generalization of MYCIN's method. This latter method requires calculation of some weights, based on a training dataset, via the use of a genetic algorithm. Creation of an expert system is outlined. Small scale experimental results comparing the above methods with each other and a neural network are finally presented.
HatzilygeroudisK10.pdf (607.8 Ko) Télécharger le fichier
hal-01060668 , version 1 (16-11-2017)
Paternité
Ioannis Hatzilygeroudis, Konstantinos Kovas. A Tool for Automatic Creation of Rule-Based Expert Systems with CFs. 6th IFIP WG 12.5 International Conference on Artificial Intelligence Applications and Innovations (AIAI), Oct 2010, Larnaca, Cyprus. pp.195-202, ⟨10.1007/978-3-642-16239-8_27⟩. ⟨hal-01060668⟩
149 Consultations
193 Téléchargements
