Cold Supply Chain Processes in a Fruit-and-Vegetable Collaborative Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
M. Victoria De-La-Fuente
  • Fonction : Auteur
Lorenzo Ros
  • Fonction : Auteur
The work presented in this paper focuses on the construction of a prototype for strategic design of nodes in a logistics network (PROCONET project). It incorporates the necessary concepts, models and supporting tools related to the design of the process flow and the choice of technology. The operation of the prototype will be validated with global supply chain processes for perishable products. Global supply chain processes will consider both full loads and groupages. Special attention will be given to the impact of INCOTERM agreements. The prototype will support intermodal logistics processes as an added value.
FuenteR10.pdf (493.06 Ko) Télécharger le fichier
hal-01060702 , version 1 (16-11-2017)
Paternité
M. Victoria De-La-Fuente, Lorenzo Ros. Cold Supply Chain Processes in a Fruit-and-Vegetable Collaborative Network. 9th IFIP WG 5.5 International Conference on Balanced Automation Systems for Future Manufacturing Networks (BASYS), Jul 2010, Valencia, Spain. pp.3-10, ⟨10.1007/978-3-642-14341-0_1⟩. ⟨hal-01060702⟩
96 Consultations
106 Téléchargements
