Collaborative Tactical Planning in Multi-level Supply Chains Supported by Multiagent Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the supply chain modeling context, the agent-based model aims to represent not only each node, but also the information sharing process among these nodes. Despite the complexity of the configuration, the agent-based model can be applied straightforwardly to support the collaborative planning process. This allows the parties to achieve common goals effectively. Thus by sharing accurate, action-based information, collaboration among the nodes will emerge to improve the decision-making process in supply chain planning processes. Therefore, this paper presents a novel collaborative planning model in multi-level supply chains that considers a multiagent system modeling approach to carry out the iterative negotiation processes which will support the decision-making process from a decentralized perspective.
HernandezPMG10.pdf (513.46 Ko) Télécharger le fichier
hal-01060731 , version 1 (16-11-2017)
Paternité
Jorge E. Hernández, Raúl Poler, Josefa Mula, David Fuente. Collaborative Tactical Planning in Multi-level Supply Chains Supported by Multiagent Systems. 9th IFIP WG 5.5 International Conference on Balanced Automation Systems for Future Manufacturing Networks (BASYS), Jul 2010, Valencia, Spain. pp.260-267, ⟨10.1007/978-3-642-14341-0_30⟩. ⟨hal-01060731⟩
93 Consultations
130 Téléchargements
