Railscan: A Tool for the Detection and Quantification of Rail Corrugation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rail corrugation is a phenomenon that leads to a waving in the rails with wavelengths typically between 3 cm and 100 cm and amplitude levels of several microns. The genesis of this waving is complex. Rail corrugation is a recognized problem that leads to excess vibration on the rails and vehicles to a point of reducing their life span and compromising safety. In urban areas excess vibration noise is also a problem. A software tool was developed to analyze accelerometer signals acquired in the boggies of rail vehicles in order to quantify the rail corrugation according to their frequency and amplitude. A wavelet packet methodology was used in this work and compared with the One Third Octave Filter (OTOF) power representations, which is currently used in the industry. It is shown that the former produces better results.
GomesBORB10.pdf (156.63 Ko) Télécharger le fichier
hal-01060764 , version 1 (16-11-2017)
Paternité
Rui Gomes, Arnaldo Batista, Manuel Duarte Ortigueira, Raul Rato, Marco Baldeiras. Railscan: A Tool for the Detection and Quantification of Rail Corrugation. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.399-406, ⟨10.1007/978-3-642-11628-5_44⟩. ⟨hal-01060764⟩
141 Consultations
90 Téléchargements
