A CMOS Inverter-Based Self-biased Fully Differential Amplifier - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2010
A CMOS self-biased fully differential amplifier is presented. Due to the self-biasing structure of the amplifier and its associated negative feedback, the amplifier is compensated to achieve low sensitivity to process, supply voltage and temperature (PVT) variations. The output common-mode voltage of the amplifier is adjusted through the same biasing voltages provided by the common-mode feedback (CMFB) circuit. The amplifier core is based on a simple structure that uses two CMOS inverters to amplify the input differential signal. Despite its simple structure, the proposed amplifier is attractive to a wide range of applications, specially those requiring low power and small silicon area. As two examples, a sample-and-hold circuit and a second order multi-bit sigma-delta modulator either employing the proposed amplifier are presented. Besides these application examples, a set of amplifier performance parameters is given.
CustodioFSG10.pdf (120.72 Ko) Télécharger le fichier
Dates and versions
hal-01060780 , version 1 (17-11-2017)
Attribution
Identifiers
Cite
José Rui Custódio, Michael Figueiredo, Edinei Santin, João Goes. A CMOS Inverter-Based Self-biased Fully Differential Amplifier. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.539-546, ⟨10.1007/978-3-642-11628-5_60⟩. ⟨hal-01060780⟩
832 View
2954 Download
Share
