Reconfigurable Circuits Using Magnetic Tunneling Junction Memories - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2010
This paper presents the first results of our work to research and develop new reconfigurable circuits and topologies based on Magnetic RAM (MRAM) memory elements. This work proposes a coarse-grained reconfigurable array using MRAM. A coarse-grained array, where each reconfigurable element computes on 4-bit or larger input words, is more suitable to execute data-oriented algorithms and is more able to exploit large amounts of operation-level parallelism than common fine-grained architectures. The architecture is organized as a one-dimensional array of programmable ALU and the configuration bits are stored in MRAM. MRAM provide non-volatility with cell areas and with access speeds comparable to those of SRAM and with lower process complexity than FLASH memory. MRAM can also be efficiently organized as multi-context memories.
SilvaFN10.pdf (202.91 Ko) Télécharger le fichier
Dates and versions
hal-01060781 , version 1 (17-11-2017)
Attribution
Identifiers
Cite
Victor Silva, Jorge Fernandes, Horácio Neto. Reconfigurable Circuits Using Magnetic Tunneling Junction Memories. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.548-556, ⟨10.1007/978-3-642-11628-5_61⟩. ⟨hal-01060781⟩
100 View
63 Download
Share
