Evolvable Production Systems: Mechatronic Production Equipment with Evolutionary Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Current major roadmapping efforts have all clearly underlined that true industrial sustainability will require far higher levels of systems' autonomy and adaptability. In accordance with these recommendations, the Evolvable Production Systems (EPS) has aimed at developing such technological solutions and support mechanisms. Since its inception in 2002 as a next generation of production systems, the concept is being further developed and tested to emerge as a production system paradigm. Characteristically, Evolvable systems have distributed control, and are composed of intelligent modules with embedded control. A concerted effort is being exerted through European research projects in collaboration with manufacturers, technology/equipment suppliers, and universities. After introducing EPS, this paper presents current developments and applications.
MaffeiONB10.pdf (793.35 Ko) Télécharger le fichier
hal-01060796 , version 1 (17-11-2017)
Paternité
Antonio Maffei, Mauro Onori, Pedro Neves, José Barata. Evolvable Production Systems: Mechatronic Production Equipment with Evolutionary Control. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.131-140, ⟨10.1007/978-3-642-11628-5_14⟩. ⟨hal-01060796⟩
85 Consultations
64 Téléchargements
