Laban Movement Analysis towards Behavior Patterns - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work presents a study about the use of Laban Movement Analysis (LMA) as a robust tool to describe human basic behavior patterns, to be applied in human-machine interaction. LMA is a language used to describe and annotate dancing movements and is divided in components [1]: Body, Space, Shape and Effort. Despite its general framework is widely used in physical and mental therapy [2], it has found little application in the engineering domain. Rett J. [3] proposed to implement LMA using Bayesian Networks. However LMA component models have not yet been fully implemented. A study on how to approach behavior using LMA is presented. Behavior is a complex feature and movement chain, but we believe that most basic behavior primitives can be discretized in simple features. Correctly identifying Laban parameters and the movements the authors feel that good patterns can be found within a specific set of basic behavior semantics.
SantosD10.pdf (212.07 Ko) Télécharger le fichier
hal-01060802 , version 1 (23-11-2017)
Paternité
Luís Santos, Jorge Dias. Laban Movement Analysis towards Behavior Patterns. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.185-192, ⟨10.1007/978-3-642-11628-5_20⟩. ⟨hal-01060802⟩
76 Consultations
189 Téléchargements
