Optoelectronic Oscillators for Communication Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce and report recent developments on a novel five port optoelectronic voltage controlled oscillator consisting of a resonant tunneling diode (RTD) optical-waveguide integrated with a laser diode. The RTD-based optoelectronic oscillator (OEO) has both optical and electrical input and output ports, with the fifth port allowing voltage control. The RTD-OEO locks to reference radio-frequency (RF) sources by either optical or electrical injection locking techniques allowing remote synchronization, eliminating the need of impedance matching between traditional RF oscillators. RTD-OEO functions include generation, amplification and distribution of RF carriers, clock recovery, carrier recovery, modulation and demodulation and frequency synthesis. Self-injection locking operation modes, where small portions of the output electrical/optical signals are fed back into the electrical/optical input ports, are also proposed. The self-phase locked loop configuration can give rise to low-noise high-stable oscillations, not limited by the RF source performance and with no need of external optoelectronic conversion.
RomeiraF10.pdf (789.63 Ko) Télécharger le fichier
hal-01060812 , version 1 (16-11-2017)
Paternité
Bruno Romeira, José Figueiredo. Optoelectronic Oscillators for Communication Systems. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.271-278, ⟨10.1007/978-3-642-11628-5_29⟩. ⟨hal-01060812⟩
65 Consultations
74 Téléchargements
