Distributed Object-Oriented Programming with RFID Technology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Our everyday environments will soon be pervaded with RFID tags integrated in physical objects. These RFID tags can store a digital representation of the physical object and transmit it wirelessly to pervasive, context-aware applications running on mobile devices. However, communicating with RFID tags is prone to many failures inherent to the technology. This hinders the development of such applications as traditional programming models require the programmer to deal with the RFID hardware characteristics manually.In this paper, we propose extending the ambient-oriented programming paradigm to program RFID applications, by considering RFID tags as intermittently connected mutable proxy objects hosted on mobile distributed computing devices.
dais_rfid.pdf (380.14 Ko) Télécharger le fichier
hal-01061078 , version 1 (05-09-2014)
Paternité
Andoni Lombide Carreton, Kevin Pinte, Wolfgang Meuter. Distributed Object-Oriented Programming with RFID Technology. 10th IFIP WG 6.1 International Conference on Distributed Applications and Interoperable Systems (DAIS) / Held as part of International Federated Conference on Distributed Computing Techniques (DisCoTec), Jun 2010, Amsterdam, Netherlands. pp.56-69, ⟨10.1007/978-3-642-13645-0_5⟩. ⟨hal-01061078⟩
122 Consultations
284 Téléchargements
