Design of Graded Trusts by Using Dynamic Path Validation - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2010
In modern information service architectures, security is one of the most critical criteria. Almost every standard on information security is concerned with internal control of an organization, and particularly with authentication. If an RP (relying party) has valuable information assets, and requires a high level to authentication for accepting access to the valuable assets, then a strong mechanism is required. Here, we focus on a trust model of certificate authentication. Conventionally, a trust model of certificates is defined as a validation of chains of certificates. However, today, this trust model does not function well because of complexity of paths and of requirement of security levels. In this paper, we propose "dynamic path validation," together with another trust model of PKI for controlling this situation. First, we propose Policy Authority. Policy Authority assigns a level of compliance (LoC) to CAs in its domain. LoC is evaluated in terms of a common criteria of Policy Authority. Moreover, it controls the path building with considerations of LoC. Therefore, we can flexibly evaluate levels of CP/CPS's in one server. In a typical bridge model, we need as many bridge CAs as the number of required levels of CP/CPS's. In our framework, instead, we can do the same task in a single server, by which we can save the cost of maintaining lists of trust anchors of multiple levels.
KuboS10.pdf (270.7 Ko) Télécharger le fichier
Dates and versions
hal-01061326 , version 1 (24-11-2017)
Attribution
Identifiers
Cite
Akira Kubo, Hiroyuki Sato. Design of Graded Trusts by Using Dynamic Path Validation. 4th IFIP WG 11.11 International on Trust Management (TM), Jun 2010, Morioka, Japan. pp.172-183, ⟨10.1007/978-3-642-13446-3_12⟩. ⟨hal-01061326⟩
43 View
87 Download
Share
