Upper Bounding in Inner Regions for Global Optimization under Inequality Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Global Optimization Année : 2014
In deterministic continuous constrained global optimization, upper bounding the objective function generally resorts to local minimization at several nodes/iterations of the branch and bound. We propose in this paper an alternative approach when the constraints are inequalities and the feasible space has a non-null volume. First, we extract an inner region , i.e., an entirely feasible convex polyhedron or box in which all points satisfy the constraints. Second, we select a point inside the extracted inner region and update the upper bound with its cost. We describe in this paper two original inner region extraction algorithms implemented in our interval B&B called IbexOpt. They apply to nonconvex constraints involving mathematical operators like +,x,power,sqrt,exp,log,sin. This upper bounding shows very good performance obtained on medium-sized systems proposed in the COCONUT suite.
innerregions_jogo_2014.pdf (530.61 Ko) Télécharger le fichier
hal-01061701 , version 1 (08-09-2014)
Ignacio Araya, Gilles Trombettoni, Bertrand Neveu, Gilles Chabert. Upper Bounding in Inner Regions for Global Optimization under Inequality Constraints. Journal of Global Optimization, 2014, 60 (2), pp.145-164. ⟨10.1007/s10898-014-0145-7⟩. ⟨hal-01061701⟩
757 Consultations
1029 Téléchargements
