Motion Law Analysis and Structural Optimization of the Ejection Device of Tray Seeder - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
An ejection mechanism consisting four reset springs, an electromagnet and a seed disk was designed for tray seeder. The motion conditions of seeds in the seed disk were theoretical analyzed and intensity and height of seed ejection were calculated. The motions of the seeds and seed disk were multi-body dynamic simulated using Cosmos modules plug-in SolidWorks software package. The simulation results showed the consistence with the theoretical analysis.
0423--Xin_Luo.pdf (241.52 Ko) Télécharger le fichier
hal-01061731 , version 1 (08-09-2014)
Paternité
Xin Luo, Bin Hu, Chunwang Dong, Lili Huang. Motion Law Analysis and Structural Optimization of the Ejection Device of Tray Seeder. Third IFIP TC 12 International Conference on Computer and Computing Technologies in Agriculture III (CCTA), Oct 2009, Beijing, China. pp.191-197, ⟨10.1007/978-3-642-12220-0_29⟩. ⟨hal-01061731⟩
88 Consultations
231 Téléchargements
