The CENDARI Project: A user-centered 'enquiry environment' for modern and medieval historians [Poster] - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This poster showcases the Collaborative European Digital Archive Infrastructure (CENDARI) project, a European-Union Seventh Framework project, which takes an innovative approach to digital historical research as well as to data integration and curation. The presenters, representing diverse disciplinary perspectives, explain their converging paths toward the creation of a research infrastructure that will further historical inquiry in the digital age.
DH2014-CENDARI_poster_abstract_final.pdf (186.63 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
Format : Figure, Image
hal-01061909 , version 1 (08-09-2014)
  • HAL Id : hal-01061909 , version 1
Jakub Beneš, Alexander O'Connor, Evanthia Dimara. The CENDARI Project: A user-centered 'enquiry environment' for modern and medieval historians [Poster]. Digital Humanities, Jul 2014, Lausanne, Switzerland. pp.434-436. ⟨hal-01061909⟩
305 Consultations
320 Téléchargements
