An Application of RFID in Monitoring Agricultural Material Products - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
With the development of modern agriculture, more and more agricultural material products are used in it. While how to keep these things safe is a big problem at present, which needs to be paid more attention. This article develops an agricultural material products monitor system based on RFID which gives alarm as soon as possible if there is anything unmoral. Every warehouse exit is equipped with a RFID reader, while each agricultural material product has a tag on them. When passing though, the reader identifies the tag's information and transfer it to the PC, The PC inquiries the database storing all tags' information, and tells which one is not taken out legally by alarming aloud.
0501--Jianhui_Du.pdf (74.57 Ko) Télécharger le fichier
hal-01062143 , version 1 (09-09-2014)
Paternité
Jianhui Du, Peipei Li, Wanlin Gao, Dezhong Wang, Qing Wang, et al.. An Application of RFID in Monitoring Agricultural Material Products. Third IFIP TC 12 International Conference on Computer and Computing Technologies in Agriculture III (CCTA), Oct 2009, Beijing, China. pp.254-259, ⟨10.1007/978-3-642-12220-0_37⟩. ⟨hal-01062143⟩
123 Consultations
767 Téléchargements
