Improving Gabor Noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 2011
We have recently proposed a new procedural noise function, Gabor noise, which offers a combination of properties not found in existing noise functions. In this paper, we present three significant improvements to Gabor noise: (1) an isotropic kernel for Gabor noise, which speeds up isotropic Gabor noise with a factor of roughly two, (2) an error analysis of Gabor noise, which relates the kernel truncation radius to the relative error of the noise, and (3) spatially varying Gabor noise, which enables spatial variation of all noise parameters. These improvements make Gabor noise an even more attractive alternative for existing noise functions.
paper.pdf (676.53 Ko) Télécharger le fichier
hal-01062522 , version 1 (09-09-2014)
Ares Lagae, Sylvain Lefebvre, Philip Dutre. Improving Gabor Noise. IEEE Transactions on Visualization and Computer Graphics, 2011, 17 (8), pp.1096-1107. ⟨10.1109/TVCG.2010.238⟩. ⟨hal-01062522⟩
138 Consultations
285 Téléchargements
