Equilibrium fluctuations for the disordered harmonic chain perturbed by an energy conserving noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
We investigate the macroscopic behavior of the disordered harmonic chain of oscillators, through energy diffusion. The Hamiltonian dynamics of the system is perturbed by a degenerate conservative noise. After rescaling space and time diffusively, we prove that energy fluctuations in equilibrium evolve according to a linear heat equation. The diffusion coefficient is obtained from the non-gradient Varadhan's approach, and is equivalently defined through the Green-Kubo formula. Since the perturbation is very degenerate and the symmetric part of the generator does not have a spectral gap, the standard non-gradient method is reviewed under new perspectives.
arxiv-corrections-07-2014.pdf (526.83 Ko) Télécharger le fichier
hal-01065976 , version 1 (18-09-2014)
hal-01065976 , version 2 (15-01-2015)
hal-01065976 , version 3 (06-02-2019)
  • HAL Id : hal-01065976 , version 1
Marielle Simon. Equilibrium fluctuations for the disordered harmonic chain perturbed by an energy conserving noise. 2014. ⟨hal-01065976v1⟩
143 Consultations
156 Téléchargements
