Marked point process model for facial wrinkle detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a new model for wrinkle detection in human faces using a marked point process. In order to detect an arbitrary shape of wrinkles, we represent them as a set of line segments, where each segment is characterized by its length and orientation. We propose a probability density of wrinkle model which exploits local edge profile and geometric properties of wrinkles. To optimize the probability density of wrinkle model, we employ reversible jump Markov chain Monte Carlo sampler with delayed rejection. Experimental results demonstrate that the new algorithm detects facial wrinkles more accurately than a recent state-of-the-art method.
2014_ICIP_SGJEONG_Submitted.pdf (1.65 Mo) Télécharger le fichier
hal-01066231 , version 1 (19-09-2014)
  • HAL Id : hal-01066231 , version 1
Seong-Gyun Jeong, Yuliya Tarabalka, Josiane Zerubia. Marked point process model for facial wrinkle detection. IEEE ICIP - International Conference on Image Processing, Oct 2014, Paris, France. pp.1391-1394. ⟨hal-01066231⟩
308 Consultations
550 Téléchargements
