Multi-Clip Video Editing from a Single Viewpoint - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a framework for automatically generating multiple clips suitable for video editing by simulating pan-tilt-zoom camera movements within the frame of a single static camera. Assuming important actors and objects can be localized using computer vision techniques, our method requires only minimal user input to define the subject matter of each sub-clip. The composition of each sub-clip is automatically computed in a novel L1-norm optimization framework. Our approach encodes several common cinematographic practices into a single convex cost function minimization problem, resulting in aesthetically pleasing sub-clips which can easily be edited together using off-the-shelf multi-clip video editing software. We demonstrate our approach on five video sequences of a live theatre performance by generating multiple synchronized subclips for each sequence.
cvmp_2014_authors_copy.pdf (2.81 Mo) Télécharger le fichier
hal-01067093 , version 1 (23-10-2016)
Vineet Gandhi, Rémi Ronfard, Michael Gleicher. Multi-Clip Video Editing from a Single Viewpoint. CVMP 2014 - European Conference on Visual Media Production, Nov 2014, London, United Kingdom. pp.Article No. 9 ⟨10.1145/2668904.2668936⟩. ⟨hal-01067093⟩
572 Consultations
830 Téléchargements
