Experimental Investigation on Heat Transfer Enhancements in Laminar Flow with Ferrofluids - Application to Power Electronics Cooling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents an experimental investigation on forced convective heat transfers in a ferrofluid with the presence of a magnetic field. The duct is square, the flow is laminar and the wall heat flux is uniform. The effects of the direction of the magnetic field and of the thermal entrance region are studied. The results show that a better enhancement is made when the magnetic field and the heat flux are perpendicular. Moreover, the effect of the magnetic field seems to be more interesting for a fully developed flow. In the end of the paper, the thermal characterization of a 3D power electronics module cooled by the same ferrofluid is carried out.
Cherief2014.pdf (352.71 Ko) Télécharger le fichier
hal-01069580 , version 1 (10-02-2022)
Paternité - Pas d'utilisation commerciale
Wahid Cherief, Cong-Martin Wu, Yvan Avenas, Sébastien Ferrouillat, Laurent Jossic, et al.. Experimental Investigation on Heat Transfer Enhancements in Laminar Flow with Ferrofluids - Application to Power Electronics Cooling. 20th International Workshop (Therminic 2014). Thermal investigations of IC'S and systems, Sep 2014, Londres, United Kingdom. ⟨10.1109/THERMINIC.2014.6972499⟩. ⟨hal-01069580⟩
193 Consultations
33 Téléchargements
