PAC-Bayesian aggregation of affine estimators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Aggregating estimators using exponential weights depending on their risk performs well in expectation, but sadly not in probability. Considering exponential weights of a penalized risk is a way to overcome this issue. We focus on the fixed design regression framework with sub-Gaussian noise and provide penalties allowing to obtain oracle inequalities in deviation for the aggregation of affine estimators. Sharp oracle inequalities are provided by a condition using the regression function's norm. MSC 2010 subject classifications: Primary 62G08; secondary 62J02.
ArticlePAC_Arxiv.pdf (215.15 Ko) Télécharger le fichier
hal-01070805 , version 1 (02-10-2014)
hal-01070805 , version 2 (24-10-2016)
hal-01070805 , version 3 (30-01-2018)
Lucie Montuelle, Erwan Le Pennec. PAC-Bayesian aggregation of affine estimators. 2016. ⟨hal-01070805v2⟩
Collections
UPMC PMA
620 Consultations
507 Téléchargements
