New interface
Conference papers
Analysis of four-bar planar mechanisms with joint clearances
Narendra Akhadkar 1 Vincent Acary 1 Bernard Brogliato 1 Michel Abadie 2
1 BIPOP - Modelling, Simulation, Control and Optimization of Non-Smooth Dynamical Systems
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
Abstract : This work deals with four-bar planar mechanisms with clearances at the joints, which induce unilateral constraints, impacts and friction, rendering the dynamics nonsmooth. The objective is to determine sets of parameters (clearance value, restitution coefficients, friction coefficients) such that the system's trajectories stay in a neighborhood of the trajectories of mechanism with no clearance. The analysis is based on numerical simulations obtained with the projected Moreau-Jean time-stepping scheme.
Document type :
Conference papers
Complete list of metadata
Cited literature [3 references]  Display  Hide  Download
https://hal.inria.fr/hal-01073482
Contributor : Vincent Acary Connect in order to contact the contributor
Submitted on : Thursday, October 9, 2014 - 6:33:19 PM
Last modification on : Monday, April 25, 2022 - 8:46:09 AM
Long-term archiving on: : Saturday, January 10, 2015 - 10:56:21 AM
File
282.pdf
Identifiers
  • HAL Id : hal-01073482, version 1
Collections
Citation
Narendra Akhadkar, Vincent Acary, Bernard Brogliato, Michel Abadie. Analysis of four-bar planar mechanisms with joint clearances. ENOC 2014 - European Nonlinear Oscillations Conference, Jul 2014, Vienna, Austria. ⟨hal-01073482⟩
Share
Metrics
Record views
143
Files downloads
371
