Analysis of four-bar planar mechanisms with joint clearances - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work deals with four-bar planar mechanisms with clearances at the joints, which induce unilateral constraints, impacts and friction, rendering the dynamics nonsmooth. The objective is to determine sets of parameters (clearance value, restitution coefficients, friction coefficients) such that the system's trajectories stay in a neighborhood of the trajectories of mechanism with no clearance. The analysis is based on numerical simulations obtained with the projected Moreau-Jean time-stepping scheme.
282.pdf (1.66 Mo) Télécharger le fichier
hal-01073482 , version 1 (09-10-2014)
  • HAL Id : hal-01073482 , version 1
Narendra Akhadkar, Vincent Acary, Bernard Brogliato, Michel Abadie. Analysis of four-bar planar mechanisms with joint clearances. ENOC 2014 - European Nonlinear Oscillations Conference, Jul 2014, Vienna, Austria. ⟨hal-01073482⟩
147 Consultations
383 Téléchargements
