Handling Breakdowns in Unmanned Aircraft Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work is devoted to activity recognition in the setting of data analysis in aeronautics. Formal methods are applied to the cer-tification and safety analysis processes of Unmanned Aircraft Systems in breakdown situations. The behaviour of these systems in case of a failure is entirely modeled and implemented. A temporal language — the Chronicle language — describes arrangements of events which are employed to detail undesired circumstances that would lead to breaches in safety. A C++ chronicle recognition tool is used to recognise all the possible occurrences of these situations as soon as they occur.
FM-Doctoral-symposium.pdf (674.25 Ko) Télécharger le fichier
hal-01076941 , version 1 (23-10-2014)
  • HAL Id : hal-01076941 , version 1
Patrice Carle, Christine Choppy, Romain Kervarc, Ariane Piel. Handling Breakdowns in Unmanned Aircraft Systems. FM - Doctoral Symposium, Aug 2012, Paris, France. ⟨hal-01076941⟩
354 Consultations
100 Téléchargements
