Propositional Merging and Judgment Aggregation: Two Compatible Approaches?
There are two theories of aggregation of logical formu-lae: merging and judgment aggregation. In this work we investigate the relationships between these theories; one of our objectives is to point out some correspondences/discrepancies between the associated rationality properties.
