Kiwano: A scalable distributed infrastructure for virtual worlds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Joaquín Keller
  • Fonction : Auteur
  • PersonId : 961184
In today's virtual worlds, even in the massively multi-player games, the number of avatars together in a virtual place barely reaches thousands. Regarding the billions of users dwelling the web, this is astonishingly low. In this paper we iden-tify spatial indexation as the bottleneck that impedes scalability and we propose Kiwano, a distributed system to scale up to millions and more. In order to split the load, Kiwano dynamically divides the space in zones, each having a server maintaining a spatial index of all moving objects within the zone. This allows to timely compute which objects are in the neighborhood of any avatar. Thus, knowing its immediate environment, the client is able compute the local scene.
hpcs2013.pdf (140.45 Ko) Télécharger le fichier
hal-01079507 , version 1 (14-01-2015)
Raluca Diaconu, Joaquín Keller. Kiwano: A scalable distributed infrastructure for virtual worlds. HPCS, Jul 2013, Helsinki, Finland. pp.664 - 667, ⟨10.1109/HPCSim.2013.6641489⟩. ⟨hal-01079507⟩
163 Consultations
338 Téléchargements
