Interference and SINR coverage in spatial non-slotted Aloha networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annals of Telecommunications - annales des télécommunications Année : 2015
In this paper we propose two analytically tractable stochastic-geometric models of interference in ad-hoc networks using pure (non-slotted) Aloha as the medium access. In contrast the slotted model, the interference in pure Aloha may vary during the transmission of a tagged packet. We develop closed form expressions for the Laplace transform of the empirical average of the interference experienced during the transmission of a typical packet. Both models assume a power-law path-loss function with arbitrarily distributed fading and feature configurations of transmitters randomly located in the Euclidean plane according to a Poisson point process. Depending on the model, these configurations vary over time or are static. We apply our analysis of the interference to study the Signal-to-Interference-and-Noise Ratio (SINR) outage probability for a typical transmission in pure Aloha. The results are used to compare the performance of non-slotted Aloha to the slotted one, which has almost exclusively been previously studied in the same context of mobile ad-hoc networks.
hal-01082772 , version 1 (14-11-2014)
Bartlomiej Blaszczyszyn, Paul Mühlethaler. Interference and SINR coverage in spatial non-slotted Aloha networks. Annals of Telecommunications - annales des télécommunications, 2015, 70 (7), pp.345-358. ⟨10.1007/s12243-014-0455-2⟩. ⟨hal-01082772⟩
214 Consultations
0 Téléchargements
