ProCARs: Progressive Reconstruction of Ancestral Gene Orders - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Background: In the context of ancestral gene order reconstruction from extant genomes, there exist two main computational approaches: rearrangement-based, and homology-based methods. The rearrangement-based methods consist in minimizing a total rearrangement distance on the branches of a species tree. The homology-based methods consist in the detection of a set of potential ancestral contiguity features, followed by the assembling of these features into Contiguous Ancestral Regions (CARs). Results: In this paper, we present a new homology-based method that uses a progressive approach for both the detection and the assembling of ancestral contiguity features into CARs. The method is based on detecting a set of potential ancestral adjacencies iteratively using the current set of CARs at each step, and constructing CARs progressively using a 2-phase assembling method. We show the usefulness of the method through a reconstruction of the boreoeutherian ancestral gene order, and a comparison with three other homology-based methods: AnGeS, InferCARs and GapAdj. The program is written in Python, and the dataset used in this paper are available at http://bioinfo.lifl.fr/procars/.
perrin_bmc_article.pdf (557.04 Ko) Télécharger le fichier
hal-01083841 , version 1 (18-11-2014)
  • HAL Id : hal-01083841 , version 1
Amandine Perrin, Jean-Stéphane Varré, Samuel Blanquart, Aïda Ouangraoua. ProCARs: Progressive Reconstruction of Ancestral Gene Orders. ISCB-Latin America, Oct 2014, Belo Horizonte, Brazil. ⟨hal-01083841⟩
225 Consultations
106 Téléchargements
