Cyclicity and invariant subspaces in the Dirichlet spaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal Functional Analysis Année : 2016
Let $\mu$ be a positive finite measure on the unit circle and $\mathcal{D} (\mu)$ the associated Dirichlet space. The generalized Brown-Shields conjecture asserts that an outer function $f \in \mathcal{D} (\mu )$ is cyclic if and only if $c_\mu (Z (f))= 0$, where $c_\mu$ is the capacity associated with $\mathcal{D} (\mu)$ and $Z(f)$ is the zero set of $f$. In this paper we prove that this conjecture is true for measures with countable support. We also give in this case a complete and explicit characterization of invariant subspaces.
JFA-14-761-RV3.pdf (179.83 Ko) Télécharger le fichier
hal-01084268 , version 1 (18-11-2014)
hal-01084268 , version 2 (20-11-2014)
hal-01084268 , version 3 (12-02-2016)
Omar El-Fallah, Youssef Elmadani, Karim Kellay. Cyclicity and invariant subspaces in the Dirichlet spaces. Journal Functional Analysis, 2016, 270 (9), pp.3262-3279. ⟨hal-01084268v3⟩
Collections
CNRS IMB INSMI
209 Consultations
217 Téléchargements
