Q-intersection Algorithms for Constraint-Based Robust Parameter Estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Given a set of axis-parallel n-dimensional boxes, the q-intersection is defined as the smallest box encompassing all the points that belong to at least q boxes. Computing the q-intersection is a combinatorial problem that allows us to han-dle robust parameter estimation with a numerical constraint programming approach. The q-intersection can be viewed as a filtering operator for soft constraints that model measure-ments subject to outliers. This paper highlights the equiva-lence of this operator with the search of q-cliques in a graph whose boxicity is bounded by the number of variables in the constraint network. We present a computational study of the q-intersection. We also propose a fast heuristic and a sophisti-cated exact q-intersection algorithm. First experiments show that our exact algorithm outperforms the existing one while our heuristic performs an efficient filtering on hard problems.
carbonnel_et_al_aaai14.pdf (580.67 Ko) Télécharger le fichier
hal-01084606 , version 1 (21-11-2014)
Clément Carbonnel, Gilles Trombettoni, Philippe Vismara, Gilles Chabert. Q-intersection Algorithms for Constraint-Based Robust Parameter Estimation. 28th AAAI Conference on Artificial Intelligence, Jul 2014, Québec City, Canada. pp.2630-2636, ⟨10.1609/aaai.v28i1.9117⟩. ⟨hal-01084606⟩
777 Consultations
115 Téléchargements
