Journal articles
Using a Modified Taylor Cell to Validate Simulation and Measurement of Field-to-Shorted-Trace Coupling
Abstract : Predicting the immunity of electronic boards to radiated electromagnetic interference requires the computation of the coupling efficiency of an electromagnetic field to PCB traces. In the case of complex PCBs, full-wave electromagnetic solvers are convenient, yet at the expense of simulation time. Therefore, this paper introduces the extension of a modified Taylor-based analytical model to the case of traces terminated at one end by a non-characteristic impedance. This model makes it possible to determine the far-field-to-trace coupling using only a sum of closed-form equations. When applied to a shorted, meandered PCB trace, it was found to be as precise as 2.2 dB average absolute error with respect to GTEM measurements, which demonstrates its relevance for immunity prediction. Moreover, the full-wave simulation of this case study was validated using the extended model and found to be as precise as 1.4 dB average absolute error.
Document type :
Journal articles
Complete list of metadata
Cited literature [8 references]  Display  Hide  Download
https://hal.inria.fr/hal-01087147
Contributor : Sjoerd Op 't Land Connect in order to contact the contributor
Submitted on : Wednesday, November 26, 2014 - 6:52:46 PM
Last modification on : Wednesday, February 2, 2022 - 9:18:03 AM
Long-term archiving on: : Friday, February 27, 2015 - 12:51:07 PM
File
OptLand-Meandered_trace_valida...
Copyright
Identifiers
Citation
Sjoerd Op 'T Land, Mohamed Ramdani, Richard Perdriau, yannis Braux, M'Hamed Drissi. Using a Modified Taylor Cell to Validate Simulation and Measurement of Field-to-Shorted-Trace Coupling. IEEE Transactions on Electromagnetic Compatibility, Institute of Electrical and Electronics Engineers, 2014, 56 (4), pp.864-870. ⟨10.1109/TEMC.2014.2313231⟩. ⟨hal-01087147v2⟩
Share
Metrics
Record views
259
Files downloads
355
