Semi-Automatic Deep Syntactic Annotations of the French Treebank - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We describe and evaluate the semi-automatic addition of a deep syntactic layer to the French Treebank (Abeillé and Barrier [1]), using an existing scheme (Candito et al. [6]). While some rare or highly ambiguous deep phenomena are handled manually, the remainings are derived using a graph-rewriting system (Ribeyre et al. [22]). Although not manually corrected, we think the resulting Deep Representations can pave the way for the emergence of deep syntactic parsers for French.
tlt13.pdf (153.16 Ko) Télécharger le fichier
hal-01089198 , version 1 (01-12-2014)
Paternité - Pas d'utilisation commerciale - Pas de modification
  • HAL Id : hal-01089198 , version 1
Corentin Ribeyre, Marie Candito, Djamé Seddah. Semi-Automatic Deep Syntactic Annotations of the French Treebank. The 13th International Workshop on Treebanks and Linguistic Theories (TLT13), Tübingen Universität, Dec 2014, Tübingen, Germany. ⟨hal-01089198⟩
224 Consultations
324 Téléchargements
