Study of a Full-Duplex Dual- Band OFDM Transceiver - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This presentation discussed system-level simulations (ADS + Matlab) on a dual-band OFDM transceiver: Such a Full Duplex node essentially consists of two OFDM transceivers, one transmitting at f1 and receiving at f2, the other doing the opposite. The system uses training symbols that are stronger compared to the regular TX signal, this allows better self-interference channel estimation and therefore cancellation ofself-interference to below the noise floor.
full-duplex_DUPLO.pdf (3.53 Mo) Télécharger le fichier
Format : Présentation
hal-01090007 , version 1 (02-12-2014)
  • HAL Id : hal-01090007 , version 1
Guillaume Villemaud, Zhaowu Zhan, Florin Hutu, Tanguy Risset, Jean-Marie Gorce. Study of a Full-Duplex Dual- Band OFDM Transceiver. DUPLO Workshop on Full - Duplex Radios and Systems, Jun 2014, Oulu, Finland. ⟨hal-01090007⟩
146 Consultations
48 Téléchargements
