Lunar perturbation of the metric associated to the averaged orbital transfer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2015
In a series of previous article [1,2], we introduced a Riemannian metric associated to the energy minimizing orbital transfer with low propulsion. The aim of this article is to study the deformation of this metric due to a standard perturbation in space mechanics, the lunar attraction. Using Hamiltonian formalism, we describe the effects of the perturbation on the orbital transfers and the deformation of the conjugate and cut loci of the original metric.
zermelo_v1.pdf (959.57 Ko) Télécharger le fichier
hal-01090977 , version 1 (08-12-2014)
hal-01090977 , version 2 (22-12-2014)
hal-01090977 , version 3 (17-04-2015)
Bernard Bonnard, Helen Henninger, Jérémy Rouot. Lunar perturbation of the metric associated to the averaged orbital transfer. Analysis and geometry in control theory and its applications, pp.65--84, 2015, ⟨10.1007/978-3-319-06917-3_3⟩. ⟨hal-01090977v3⟩
470 Consultations
678 Téléchargements
