Formal Proofs of Rounding Error Bounds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Automated Reasoning Année : 2015
Floating-point arithmetic is a very efficient solution to perform computa-tions in the real field. However, it induces rounding errors making results computed in floating-point differ from what would be computed with reals. Although numerical analysis gives tools to bound such differences, the proofs involved can be painful, hence error prone. We thus investigate the ability of a proof assistant like Coq to mechanically check such proofs. We demonstrate two different results involving ma-trices, which are pervasive among numerical algorithms, and show that a large part of the development effort can be shared between them.
submission.pdf (262.29 Ko) Télécharger le fichier
hal-01091189 , version 1 (04-12-2014)
hal-01091189 , version 2 (26-08-2015)
Pierre Roux. Formal Proofs of Rounding Error Bounds: With application to an automatic positive definiteness check. Journal of Automated Reasoning, 2015, pp.23. ⟨10.1007/s10817-015-9339-z⟩. ⟨hal-01091189v2⟩
468 Consultations
2138 Téléchargements
