The Geometry of Synchronization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We graft synchronization onto Girard's Geometry of Interaction in its most concrete form, namely token machines. This is realized by introducing proof-nets for SMLL, an extension of multiplica-tive linear logic with a specific construct modeling synchronization points, and of a multi-token abstract machine model for it. Inter-estingly, the correctness criterion ensures the absence of deadlocks along reduction and in the underlying machine, this way linking logical and operational properties.
main.pdf (713.02 Ko) Télécharger le fichier
hal-01091560 , version 1 (05-12-2014)
Ugo Dal Lago, Claudia Faggian, Ichiro Hasuo, Akira Yoshimizu. The Geometry of Synchronization. Joint Meeting of the Twenty-Third EACSL Annual Conference on Computer Science Logic (CSL) and the Twenty-Ninth Annual ACM/IEEE Symposium on Logic in Computer Science (LICS), Jul 2014, Vienna, Austria. ⟨10.1145/2603088.2603154⟩. ⟨hal-01091560⟩
471 Consultations
290 Téléchargements
