Label-free Modular Systems for Classical and Intuitionistic Modal Logics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we show for each of the modal axioms d, t, b, 4, and 5 an equivalent set of inference rules in a nested sequent system, such that, when added to the basic system for the modal logic K, the resulting system admits cut elimination. Then we show the same result also for intuitionistic modal logic. We achieve this by combining structural and logical rules.
modul-modal.pdf (541.97 Ko) Télécharger le fichier
hal-01092148 , version 1 (08-12-2014)
  • HAL Id : hal-01092148 , version 1
Sonia Marin, Lutz Strassburger. Label-free Modular Systems for Classical and Intuitionistic Modal Logics. Advances in Modal Logic 10, Aug 2014, Groningen, Netherlands. ⟨hal-01092148⟩
556 Consultations
119 Téléchargements
